- May 6, 2010
- Threads
- 51
- 11,261
Most likely you will need to remove the pulleys to get to the engine mounting bolts to at least change the angle on the engine to get to the drain hose. Kohler engines are bad for having the hex on the drain plug fitting or hose so close to the mower frame you have to remove the engine just to be able to turn the hex.
