CV15S cylinder damage
I have a customer who has a 20 year old John Deere SST15 with a Kohler CV15S engine. He ran it without oil and, well, you know what happened. I'm trying to put a new crankshaft and connecting rod in it. However, when the connecting rod failed, it impacted the bottom of the cylinder and broke a chunk out. There appears to be wear marks in the cylinder. I don't think the piston travels down to where the damage is. Can I get this engine running or is the crankcase unusable?
that will be fine
get a die grinder or similar and make the hole smooth left right & top bottom so the edges do not break away
I agree with Bert that it will be fine. I would let the customer know what you found and let them make the choice on how to proceed.
