bellevuebill
- May 7, 2010
- Threads
- 1
- 3
I have about 4 acres that I mow.  I have not used fertilizer or weed control in the past.  I always figured that as long as it was green it was ok :biggrin:.
Now that I want to start controlling the weeds I was curious as to which method of applying fertilizer is most effective, a liquid sprayer mounted behind my lawn tractor or a pull behind broadcast spreader?
Is there a cost difference between liquid and dry fertilizers?
Which method do you use and what are the benefits or problems with each?
