I have a Briggs & Stratton 3000/2000 watt generator that wouldn't start, so I pulled the carb apart and it was all gunked up. When I took off the float there's some very thin and small plastic tabs that hold on the needle valve and one of them snapped. I can't find this carburetor or a rebuild kit anywhere. Every site shows no parts available. I ordered a carb off ebay that looked similar and specifically said it was only for the 030239 generator and it was too small so I returned it. All the carbs on ebay that are for 030239 are the same type of carb as the wrong one I received. The carb on the generator is a Nikki with numbers C118521 and 5XK on the side. On the "nikkicarburetors" web site they only have one carb that looks similar but the choke lever is on the opposite side and the holes on each end of the carb are opposite. On B&S web site it looks like float 694914 or 699724 might work but the pictures aren't clear and I can't tell the difference and the price is outrageous. Anyone know of a replacement carb or rebuild kit for this thing? In the picture of the carbs below, the left carb is the one from ebay and the right is the one off the generator.
