Sears/Craftsman has a lot of models. Not a knock on Craftsman, but if you don't have the model and serial number you could encounter problems finding the right parts.
Well how will I know exactly what part around the spindle that needs to be replaced?
If you take the (few) front end pieces apart, you will see if the nylon bushings are trashed... same with bent ears on spindles...
Post a couple pictures of your tractor, include a close up shot of the spindle & tie rod area...there is a good chance someone will recognize it...
:smile:KennyV
