tractor front wheels pointed out
boston
My craftsman tractor front wheels are pointed outwards instead of straight. It's not a huge problem but it affects my turning radius when I'm mowing or cruising . The wheels look like this: \-/ . I don't know if I need to replace a part or adjust something
If they look like that you need to have a front end alignment done. Do you have a manual for the mower, if so it should tell the correct procedure to do the toe in adjustment.
My wheel horse has adjustable tie rods, but I am going to take a guess your craftsman doesn't. But if it does just adjust the wheels straight with a tape measure. The most likely thing that happen you bent a spindle by hitting something or a tie rod which isn't so likely. You are going to have to take some measurements to figure out what is bent or worn out and go from there.
Along with bent parts causing that... check the bushings. If they are worn out, the wheels will toe-out... :smile:KennyV
Is there any way I can see a diagram of this and the parts I need for the repair?
You will need a tractor model number then a parts search You should be able to find a parts diagram with all the part numbers. Your best way would be to call Sears with your model number and tell them what you need. Did you figure out what was bent or worn? If you give me your tractor model number I could help you a little better because I really don't know what you have? I am just guessing what your problem is or how to replace your spindle from other jobs I have done.
Sears/Craftsman has a lot of models. Not a knock on Craftsman, but if you don't have the model and serial number you could encounter problems finding the right parts.
