Bad boy magnum mz 725cc
Still waiting on the results from the tests I asked for back in post # 1
This will tell us if you have a mower problem or engine problem .
IF people can not be bothered to do the simple things I ask then I can not be bothered trying to help them
Hi, this is Simon's father. (Simon is the OP.) The starter is turning the flywheel, but there is no spark. I disconnected the coil pack ground wires, cranked it, and the coil packs are generating power when the flywheel is spinning. So, I guess this is a ground wire issue?
