- Sep 24, 2017
- Threads
- 288
- 6,883
heat and quinch. heat the rim/axel up cherry red, quinch it with a water hose.
Extreme heat and Extreme cold. The best way.Which is why I use the jacks & air hammer
Look at the video link & learn .
As the last resortExtreme heat and Extreme cold. The best way.
I heated it up but not to cherry red. Are you talking about the outside of the wheel or the inside where the hub goes over the axel ? I only have cans a MAPP gas. How long does it take to get it to cherry red?heat and quinch. heat the rim/axel up cherry red, quinch it with a water hose.
Duh. Gotta get them off first!Get all the rims off and ati-sneeze them for the next guy. Blade bolts, spindle bolts and so on.
Good tip sir.Duh. Gotta get them off first!![]()
