Well I have different luck myself.I can't count the number of carbs I got off Amazon - have not ran across a bad one yet
That is likely your problem. You probably bent the rod that goes to the carb butterfly and the rod is rubbing on the breather hose. Another problem often caused by the repair person is they bend the rod going to the choke thermostat and it will rub on the engine cover. For further reference, these plastic carbs rarely (if ever) need replacement. The plastic cleans easily and does not corrode.Hi Folks, Kinda at my wits end with this one. I have a 2019 Troy built mower, engine model 09P602. I am helping my older neighbor. Been setting up for a year. It would not even fire. Spark tester showed a bad coil which I replaced . It started but would only idle and eventually dies. I replaced the black plastic carburetor (startzeal 799583) figuring it was a mess.
also I have not heard good things about them after setting up for a long period. So, clean gas, new coil, new carb, new plug. I can get it to start but only idle rough and die. I am not sure how all the linkage works for the throttle but that seems to be the only thing I have not touched.
I have a 2016 Poulan with the same carb and the same problems. Every year I would need to disassemble and clean the carb (though there was never anything visibly amiss with it) then it would start and run OK for the year. Let it set for the winter, treated fuel, gumout added, doesn't matterHi Folks, Kinda at my wits end with this one. I have a 2019 Troy built mower, engine model 09P602. I am helping my older neighbor. Been setting up for a year. It would not even fire. Spark tester showed a bad coil which I replaced . It started but would only idle and eventually dies. I replaced the black plastic carburetor (startzeal 799583) figuring it was a mess.
Any ideas?
Most of the aftermarket carburetors I order from Amazon have been plug and play and run great. Exceptions are often Kohler carburetors that run lean and require drilling out pilot jet slightly. These plastic carburetors cannot corrode because they are plastic, easy to clean and service. Install fuel shut off valve and run out most of fuel in carburetor during off season of use, majority of fuel issues solved.I have a 2016 Poulan with the same carb and the same problems. Every year I would need to disassemble and clean the carb (though there was never anything visibly amiss with it) then it would start and run OK for the year. Let it set for the winter, treated fuel, gumout added, doesn't matter
The carbs IMHO are cheap Chinese plastic crap. I ordered one online, if it solves the problem, good. If not - yard sale
Not worth the BS.
