grumpyunk
You might just try loosening the PS adjustment screw. They are mostly spring loaded switched with an adjuster to change the open/close pressure. If adjusted too high(by someone trying to get it to run) it would not shut off no matter the pressure. If you look at the PS I expect(do not know) that you will see a spring with a threaded shaft sticking out of it. The shaft is attached at the base, and it has a 'plate' that rides on the shaft and compresses the spring. If the spring is compressed too tight, the switch will not operate. Too loose and it will not turn on. Generally you tighten the screw (CW or CCW) to make the plate/washer/?? push down on the spring harder for higher pressure, loosen to make the spring push less.
All PS have a range. Yours is likely close enough. IMO. BTW, not a plumber either.
tom
tom
