shadetree#1
- Oct 31, 2022
- 153
Final test: cables directly from car battery at 12.40V, Neg cable to engine grounded, Pos cable to starter post (still measuring 12.40V), I get a spark, but starter DOES NOT WANT TO TURN!. Sheeeeeesh!
TAKE THE SPARK PLUG OUT AND SEE IF THE STARTER WILL CRANK THE ENGINE OVER.
You need to keep a heads up and not burn/toast/smoke your starter by holding voltage on it too long.
Them replacement starters are expensive for that Tecumseh.
Here is a link to look at parts lists using your model number.
