kyriverguy
only starts when using starting fluid , Replaced: air filter ,vent filter ,carburetor , spark plug ,fresh gas ,spark arrestor is clean. Any suggestions ?
Need to perform leak down test both vacuum and pressure with Mighty Vac tester. Need to pull muffler and check condition of piston, rings, and cylinder. A saw of that age needs these tests performed before going any further.If all the rubber on the 025 is original it really is time to replace them. Fuel, oil and impulse hoses. Fuel and oil filters. The crank seals and intake boot and the clutch drum bearing for good measure. Some stuff is available OEM still or aftermarket from HL Supply. Crank seals are fun to change. I just did an 028 a couple weeks ago.
Since you say it runs on starting fluid it has at least enough primary and secondary compression to run the saw.
Remove the carb and see if you can easily suck fuel out of the fuel line. If you can then install carb and pull the rope a dozen times then remove carb and remove the fuel pump side of the carb ( one screw) and see if there is fuel in that part of the carb. If not your impulse is not working. The small hole in the rubber intake boot the carb bolts up to is the impulse.
Kinda assumes he has the tools and know how to do that.Need to perform leak down test both vacuum and pressure with Mighty Vac tester. Need to pull muffler and check condition of piston, rings, and cylinder. A saw of that age needs these tests performed before going any further.
Merry Christmas!
That's one of the problems here with users. Most don't have the knowledge yet alone the proper tools. Even with all the tools I have I am constantly having to add specialized tools.Kinda assumes he has the tools and know how to do that.
