Kmh72412
MODEL NUMBERwhat problem came first?
How much use had the engine seen without that problem before it happened?
engine model number and serial and/or at least Pony model number and serial.
What spark plug number are you running in it?
13AN77KG011
SERIAL NUMBER
1D239B462010
00001
The spark plugs have been 3 different ones, not sure the model numbers off the top of my head, just the called for one by the manual brands being Champion, Autolite, and not sure of the other.
The surging seems to have been happening with the overheating muffler and melting coil wire, though now with a new carb the engine runs fine but it still overheats.
