sectlandscaping
Did a late season pressure wash and the customer gave me a lawn vac/blower, chipper. Its a no name brand garden way, I believe it was made by bolens before mtd took over. Anyways its a 4 hp tecumsah. That seems way to weak to blow leaves. How would I know if a bigger engine would fit?
It wouldnt start so I tried to take apart carb but the screws are stripped on one side. I was able to give it a partial cleaning. When I went to put it back together I messed up the gov linkage. When I switch it from off, slow, fast the linkage doesnt move. I didnt disconnect the spring its the part that goes on top and moves the choke that im having trouble with. It would be easier if I could get the carb dissembled.
I found a hole in the primer bulb too. I was able to get it to run for about 10 seconds by putting my finger over the primer but it was put putting. On top of that the thread on the muffler bolts are stripped but I dont see how that will effect operation.
The model # 47021 the engine # tvs115
