Joe Z
The grease gun will not work if the bearing is sealed on the inner side. WhyOur cub was eating belts. I fixed it be repacking the spindles. Take them apart and clean and regressed. Using the grease gun did not do it!
Not to repeat what was already said I read a few of the comments. Did not read all of them but the few I did read gave some good information/ advice. If your bearings are bad it is not too difficult to replace them. When you buy new bearings geese them before installing. I had them delivered with very little grease. Let us know how it turns out.Mine is a 23/50 force cub cadet. My belts keep breaking. I'm thinking the pulleys are not right. Seem it shreads my new belts as fast as I can put them on? Any suggestions?
