bkeller500
It sounds like it was all about the belt routing. somehow it must have been installed incorrectly. There should be a belt diagram available on-line or from one of those dealers to look at.
I know, but this belt can only go on one way for the idler to function. In the back of my mind I think the repair shop didn't want to share what they did with my shop. My shop is scratching also. I have belt routing diagram and I'm sure my shop would have found something that simple. ??????????It sounds like it was all about the belt routing. somehow it must have been installed incorrectly. There should be a belt diagram available on-line or from one of those dealers to look at.
You may be correct in that. I told the shop I wanted the old units. I want to jig up a test stand and check them out. I'll have to get the rpm from somewhere, then jury rig to a electric motor. I'm thinking they will check out ok assuming the routing was a problem to begin with. I've made mistakes before, but I have changed this belt several times in the past. I couldn't sleep last night from thinking about this. lolI think the first didn't know what they were doing. I see this a lot around here even some the brick and mortar shops are a hopeless cause at times as they hire unqualified techs.
As said it is rare for both units to fail at the same time.
