Yes there can be big price differences. What I just wish is for stated sizes of after market be the actual size of the belt being sent. You probably know as well I do different specs can affect the fit and sizing. Yes I do have a few model here that uses a size smaller belt that the spec'd belts. And of course my personal MTD mower is running a 5/8 deck as I just kept burning up the 1/2 belt due the grass I cut and the larger engine that is on it. I actually running a Husqvarna sized belt on it.
At one time I used a lot A&I as they were the size they stated on the belt sleeve but that no longer the case. I had to change many customer installed A&I belts because of this. I also had problems with Stens belts, not a lot, but still every once a while I get that is long than the stated size which of course causes problems. I can trust more than A&I. It seems so far the PIX belts are what they say they are size wise.
MTD products is the exception as they use odd belts and you general have to use their belts especially when it come to drive belts.
Oh well off to the bank with all the millions I made last week of repairs.? Barely enough to even pay the bills.
