- Feb 19, 2020
- Threads
- 116
- 12,573
Good chart, i'll have to remember itYou got it. BPR is 13/16" and the BKR is 5/8". Other than that the specs are the same.
What's different between the BPR and BKR? different hex size?
champions also seem to have a higher heat range, but get hot quicker on my engine, probably because we are go-kart tuning it so it will be at full throttle a lot of the time when we accelerateI have found that Champions seem to give less problems in 2 strokes
So I use NGK's in most 4 strokes & Champions in most 2 strokes unless the customer specifies a particular plug brand
I also stock Bosh plugs as I got a good deal on 400 of them .
