5 HP CRAFTSMAN edger engine muffler is loud and leaks from crack in middle
Craftsman Garage
  • / 5 HP CRAFTSMAN edger engine muffler is loud and leaks from crack in middle
yeah, those are the exact ones, why?
Craftsman Garage
yeah, so this afternoon I cleaned the air filter, re-gapped the sparkplug which is SUPPOSED TO BE 0.030, BUT WAS AT 0.060, and shot a bit of seafoam deep creep into the needle hole, and this thing... ok, I start it right up and immediately notice the difference of tension in the throttle, and at full throttle, this beast sounds insane loud, is a champion at edging, and could be a 40MPH GO-KART engine. Wow, the things seafoam can do... by the way, the real "champion" is the champion sparkplug hahaha.
Scrubcadet10
Moderator
Staff member
I imagine closing that gap down helped Tremendously....
Craftsman Garage
it absolutely did, and it's very surprising that it started too... weird
Craftsman Garage
also, how would be the best way to clean the reusable foam air filter? water didn't seem to do anything.
sgkent
I replace them but you can wash them in kerosene or even gasoline OUTSIDE AWAY from flames, and let it dry. Or just some hot soapy water in the sink should clean it too. If you have some mineral spirits or stoddard solvent that works well too and is less flammable.
Any type f solvent or fuel will cause the filter to disintegrate. Hot soapy water works best.
