Engine cuts out
With out the requested info being provided most things posted are just guesses. Cub Cadet (MTD) uses three different systems that I know of and must know which of three that is being used here. Apparently the OP isn't really interested in fixing the problem so I am stepping out of this thread.
sorry , i have been away for some family stuff :(
yes, it wont start after reverse mow, and now does not start at all with out a jump, it would seem the battery is not charging ty
Need the model number from the serial number tag so we can pull the wiring schematics. Also have you recently changed the ignition switch or seat switch?
hi there, the model number is ...............................13AVA1CS056..................date of manu........12/2016
Okay your ignition switch is the MTD RMC switch setup using the Delta 6900-47 switch. Here is the pin out for the switch.
Electrical Schematic
If you need to replace the switch you use the Oregon 33-105 or if you don't mind having a wrong symbol use the Husqvarna 532175566.
The Oregon Switch is the non printed/ non molded version that MTD/Cub uses. The Husqvarna is the printed and will have a headlamp symbol in placed the reverse mode symbol. It is due to way the switch is used here. The switches with the reverse symbol will not work in this application.
