macelandscaping
Posted this to another thread just now. I am having almost the same problem as yours. What do you think??
"I have a scag wildcat 52" (prior 2011 model, I will get a VIN asap) with a similar issue. Same thing where someone previous did play with some wiring. My issue is that I have intermittent power to the blade pull switch and NO power at all with the key in any position. When I say no "power" I mean that it is dead and does NOTHING...I replaced the ignition and clean all connections, replaced both fuzes, checked all safety switches for continuity (all came back good), I haven't found any wires so far grounding out or that are severed. There is a ballast resistor I believe that it on the side of the engine next to the starter, checked it for continuity and it has it. There is something similar (some type of resistor or module?) on the left side if you are sitting on the mower that has about 8-10 wires going into it and it is sealed with a gel/tar. I believe it is number 17 on page 66 of this manual. Is there a way to test it? What problems could that part produce?
http://www.scag.com/OPManuals/STWC/2...273 Rev2.pdf
Also, number 9 in the same picture is a relay. Might be having issues with it, maybe not. I made jumper wires and wired around it in efforts to get off a job site with intermittent success so it leads me to think it might not be an issue... I have to admit that I am totally lost here... Has anyone had similar issues? Thanks in advance!"
