Kawasaki fs691v fuel filter
NHC
Just bought a new fuel filter and it is not the same as what came originally on my new mower. I took my engine model and serial numbers with me. The original one on my engine is a Kawasaki 49019-0031. Is this supposed to be the correct one for fs691v ?
Thanks
Is it a 49019-0027 or a 49019-7001? It really doesn’t matter as long as your fuel line fits and it's for a mower with a fuel pump. You could use a Kohler or Briggs filter for that matter.
The new one they gave me just has tw fastex and the flow direction arrow on it.
If it was a genuine kawakasi filter it should have come in a white plastic bag branded Kawakasi with a part number on it .
If not then you have been supplied with an aftermarket filter
If the filter has a brand name then it should be a good one
If you asked for a filer to fit a FS691V then the shop can sell you any filter that fits that engine if which there would be at least 100
If OTOH you asked for a 49019-0031 then the shop is obliged to sell you the original Kawakasi part or an equivalent genuine Kawakasi part .
FWIW I never fit genuine parts unless specifically asked to do so otherwise every mower gets the same Prime Line filter.
All that is important is the micron size is near that or the original and the flow rate.
I am yet to see a filter that will not work properly
I use this particular filter because the outlet internally is flush with the end of the filter so you do not get air trapped in the filter .
This does not affect the running of the engine but the customers with no idea about small engines would ring back complaining that the filter was not full. so I changed the style
EFI engines get a finner filter that is in a metal canister
I use the same "high pressure" filter on all fire pumps after a customer had a plastic one go soft and collapse when he was fighting a fire .
Mind you the radient heat was enough to blister the paint on the fuel tank & the frame but I would hate to put a customer in danger for the sake of a $ 10 fuel filter .
ITW Fastex: Chinese filters that the guy gets by the box full. I sure wouldn’t run it on anything of mine.
Use genuine Kawasaki, Briggs or Kohler and you will be okay.
Yep, this is what i came up with when searching that
OP, you can get oem Kaw parts at any of the following.
Did you happen to see the specs on that thing? Sustained 160F temps can distort the plastic housing. Folded paper elements. Not with a 10’ pole.
Thanks for all the replies. I ordered the same Kawasaki filter that I originally had, and it was a little cheaper than the filter they sold me. I always try to use oem parts if possible.
