Engine bad, need to repower
Downloaded another manual. It reads:
126T05-4678-B3. B&S, 675 Series, ES, X, B3 for the engine. Does anyone know what engine would mount the same, use same blade but be an upgrade? TIA
Is this the crankshaft specs that need to be the same as replacement engine?
126T05-4678-B3 is replaced by 126L075662 which has a
25-MM Diameter by 3-5/32-Inch Length Crankshaft​
so it looks like a 25MM with 3 5/32 is what you need.
if you want to find something cheaper, look at small engine wharehouse, and you can filter your results by selecting, Recoil start, and Crankshaft Length and Diameter.
I sent them an email to fund out if that 10tp will work.
They replied:Thank you for the information regarding your engine. Unfortunately the information provided does not register as a valid model by the manufacturer. Please check and resubmit with the complete model and type number.
So I sent them this photo.
