Remove the muffler & see if it will try to start.
If you have fuel, compression and spark, all at the appropriate time, the only thing I can think could be a blockage in the muffler may prevent it from starting... :smile:KennyV
Outdooz said:Ok i dont know the name of the weed eater or the model.
Theres a spark
Cleaned the carbuator
New gas
Made sure gas was getting to the carb
But still no start!!
I even tried using starting fluid.
What could be the problem?
