My lawn mower won’t start after tipping the spark plug area up to the sky
  • / My lawn mower won’t start after tipping the spark plug area up to the sky
are you sure there should be gas in the filter? I don’t think there should be any.
Should be some fuel in the fuel filter. No gas in the air filter.
Remove the fuel line AT the carb. Drain into a glass jar. Should have good fuel flow there. Verify this.
As stated remove spark plug and pull the rope several times. Let it sit a while to dry with plug out.
If all this fails, remove carb bowl. Should have fuel in the bowl. DON'T over torque the bowl nut. Just a gentle snug is all you need.
Probably could use a carb cleaning while you are at it.
dom22
Need to keep the oil at the FULL mark. Not over and not under all the time. Check oil PRIOR to starting your mowing. Use plain ol' tried and true SAE30 oil.
Will fill it up with fresh oil when I get back home ??
Scrubcadet10
Moderator
Staff member
are we talking like one of these filters?
Or
If it's FUEL filter, there should be gas in it...
dom22
It’s all fixed, I changed the oil and spark plug and it seemed to fix. Thanks for all of your help!
Scrubcadet10
Moderator
Staff member
No, it’s an air filter. I think we’re talking about 2 different filters.
oh yeah, shouldn't see gas sitting in the air filter...
glad you got 'er going.
