Gord Baker
- Aug 21, 2018
- Threads
- 1
- 488
Hopefully if there are timing gears, they were installed correctly. Timing marks on each. Check coil to Flywheel clearance (a stiff business card) and that the key was put in the crank to Flywheel groove.Hi everyone, I have a Lawn Boy C10 Iron Horse that I totally rebuilt. The only original parts are the cylinder sleeve and the crankcase. I have compression and a great spark. i can not get it to run and am open to any ideas. Thanks
Try it with dry spark plug in and connected and with Starting Fluid. If it does not fire you have an electrical problem.
