Where the %&$#@ does this spring go?
I have an 18TwinII on my Case 446. I cleaned the carburetor 2wc and it was still surging. Then the fuel pump started leaking so I bought a new carburetor and now it runs great. The original had 3 bolts on the fuel pump and the new one has 4 so either will work. I'll look and see if I can spot that spring on my engine.
Save the OEM carb if it is OEM. Clean it a few more times. Keep it for a backup.
Well I thought I hit the jackpot today. Saw an old craftsman sitting in a yard so I thought I'd ask to look under the hood. Be my guest was the reply. So I did and there was the mystery spring in all it's glory hooked from one end of the bell crank to the other end of the bell crank ?. Maybe it's just for show after all.
Kinda looks like the spring that connects the throttle to the governor linkage so when you move the throttle, it provides a steady pull on the throttle linkage. It is needed to maintain pressure as the governor does it's governing thing.
