Good Morning,
Last summer I purchased a new Cub Cadet XT1 (LT50) that replaced an older Cub Cadet LT1050. Prior to both of these mowers, I've never had an issue with grass accumulating under the mower deck. I spend about 30 minutes performing grass removal after every cut, and it's a pretty big amount that I'm pulling out . Is this an issue with Cub Cadet mowers? It's used to cut two properties that total a little over 2 acres and the salesman said this model would handle the acreage. Also, most of the grass is full sun, but there is an area that gets late sun and might not be as dry as the majority of the area. The grass is being cut at a height between 2.5" to 3". Any ideas of either what might be going on or strategies to combat it? I can't spend another summer up to my elbows in grass stains.
