poconomower
hello...i have a command 20 hp hora shaft engine,,,,,,the engine stopped running on the owner...out of 4 valves i have one that the push rod is moving normal and 3 that dont move at all....being that one is moving good i dont feel its the crank gear or it seems none would move...any ideas? could it be oil pump ? blocked filter? can i put oil down top of lifter to fill is and see what it does?
