B&S on a DC silver eagle wiring & misc help
Preston1977
I’ve done some searching on here and I’m at a point to where I’m kinda stuck. I have a 2008 Dixie Chopper Silver Eagle SE that I just bought and restored. It had a 27hp Generac that grenaded on the guy I bought it from. I’ve replaced it with a 27hp commercial series Briggs & Stratton. At the back of the mower where the Generac used to plug in I’ve figured out the ignition wire that goes to an external starter relay, and a ground that I’ll have to use to shut the B&S off at the coil. On the B&S there are 3 wires in a plug, grey, red & black. I don’t know what to do with those 3 wires.
My other dilemma is this mower was a parts mower for someone and there was a lot of stuff torn off of it, it sat up outside for the last 8 years and no one remembers anything about it. I need help with the size bolt that goes in the shaft on the B&S
Hope you survived the storm.
The grey should go battery voltage with the ignition turned on
If so it goes the solenoid on the carburettor .
The black should be open circuit to ground with the ignition turned on & ground when the ignition is turned off and if that is the case it goes to the magneto .
The red will be battery voltage and goes to the rectifier
For the most part we did, it’s all minor stuff but a lot of minor stuff.
Thank you for the reply on the B&S lol. I’m going to hop back on it tomorrow afternoon once Dr CrossFit gets home and I get relieved of dad duty.
Another question I had, that little piece in the pic below was flopping around in what was left of the box the motor was shipped in. What is it for?
