Very rare for a flywheel to go bad other than the magnets falling off or breaking away & joining together .
Kohler use regulator rectifiers , not plain rectifiers so they only allow power through when there is a need for it
So make triple sure that the resistance between the red wire on the rectifier and the battery is 0 with the ignition turned on .
The alternator will not generate if it can not see the battery needs charging .
A trick that works well when I suspect that there is a problem with the charging circuit is to connect a battery charger to the + wire on the rectifier plug ( plug disconnected from rectifier ) and the - on the battery .
Turn the charger on then check the voltage at the charger and at the battery .
They should be almost the same
do this with both the key turned on & off .
If I am still not convinced the charging circuit is good, I slip an old headlight globe between the battery & charger to put a load on the circuit.
Kohlers seem more prone to wires breaking at the crimps so they just touch
In this condition they will show continuity with a volt or ohm meter but will not carry a load .
Gets really frustrating when you keep seeing continuity but that moungrel battery just won't charge
