HazyOmega
Hello All,
Mower: Honda HRX217K5HYCA
So I'm having issues with my mower. It's always start at the first pull but engine is really unstable surging up and down until I stabilize the governor with my finger. After stabilizing, the engine is running smoothly and doesn't surge anymore when cold. After about 2-3 minutes, when the engine gets hot, it does fluctuate slightly and there's popping sound coming from the exhaust. Bought the mower new back in 2016; it started surging after 2 months of usage. I figured it was my fault because I put 91 octane fuel in without stabilizer and it gummed the carbs. It's the model with the blade clutch, when the blades are engaged, the engine doesn't surge so I didn't cared much for 5 mowing seasons because it's running fine when mowing. You know, first time homeowner then first kid ... you have better thing to do than repairing a small engine and the years pass...
So, I decided that this years I'll do a "big" maintenance on the thing and change the air filter, spark plug, oil (change each season), sharpen the blades and clean the carbs. I wanted to get rid of the surging.
I read thru a lot of forum and everything seems to point towards a lean mixture. I believed one of the jet may be partially blocked so I decided to clean the carbs. Pulled it from the engine, used carb cleaner put it back. Still surging. I pulled it again and cleaned it using ultrasonic batch. It's still surging.
Now, assuming I did a correct job cleaning the carb, what else can cause this?
