Carburetor replacement issue
amateurmechanic
I replace the carburetor on my craftsman Ltx1000. Everything looks the same and fits nice except the fuel solenoid goes off to the side instead of straight down. Because of this the wire does not reach. What can I do? Can I somehow extend the wiring? Thanks.
Yes you can extend the wiring as likely only a two wire setup and solenoid is not polarized. Just depends you ability to do proper extension.
Easy repair to splice in a piece of wire. Compression fit sleeves come in kits complete with crimpers. Good to have kit in your shop.
remove carb, remove bowl screws, turn bowl and replace screws, that should position it to reach with the wires you have
if it doesnt appear that will allow it to reach then yes just cut the wire and add in a short extension
