jakesmurray
I just checked the plug again, and it is a little wet, so there is fuel getting into the engine. Now, I will completely clean the fuel system and make sure there is no old fuel in the system.Sounds like you have old gas in the tank for 1
As for the trickle of gas coming out.... it should be a good stream while cranking.
If the valves are out of adjustment then the vacuum from the head might be low and not allowing the fuel pump to work right.
Are you sure the plug is bone dry?
Clean the carb and make sure all the passages are very clean and that you can blow air thru fuel port. Also make sure with this carb that your needle below the float seals well. while the carb is inverted blow thru the fuel line and make sure you are not getting any air past the needle seat.
Rob
