DGillen
I've seen this asked about but this has become beyond frustrating. The belt will not stay on and it's been being an issue since I bought it new. I put a new belt on last year and it still started jumping off again after just a couple of uses. That can't be normal. I had figured out that if I started and stopped the blades with the deck raised up it would go longer without jumping off but now that's not helping anymore. I'm going to buy another new Cub Cadet belt today and hopefully get it installed before the rain comes in. Is there anything you guys can suggest to stop this from happening? The belt guides are in place but it jumps off of the blade pulley and I have to remove the guard to put it back on. Also, there seems to ve excessive slack in the belt even when new and I've made sure the front hanger is in the correct location on the mount. Thanks!
