42 inch rider blades noise
bassman37
I have a Craftsman model number 917.25081 which is a 19 HP Briggs & Stratton Platinum series T 2200.
When I disengage the cutting blades I hear a sound as if the blades are hitting metal or each other until they come to rest. I have checked under the deck and the bolts on both are tight.
Any idea as to what I should check or my issue may be?
Thanks in advance!
Reach up under the deck and try to shake the blades with the belt loose. Should not wobble and should rotate smoothly. Slim chance there's a blade brake that's loose or worn out too. but doubtful.
i think its also very likely the brake pads that stop the blades from spinning when you disengage the blades, are worn right through to the metal backing.
its very common
to test this, with mower off, engage the blades, this releases pressure on the brake pads, then spin the blades by hand (very carefully) and see if its still making noise. inmost cases if the spindle bearing are bad enough to hear noise over sound of engine then its so loose its flopping around in the hole
Is there accumulated gunk on the bottomside part of the deck? When you spin the blades by hand do you hear/feel noise? Yes- with engine OFF !!!
Thanks Tom. The blades rotate smoothly without any wobble so I guess the spindle bearings are OK.
its very common
Thanks Keakar. When I ran the test that you suggested I hear no noise from the blades or bearings.
Thanks Cusser. The bottom of the deck is clean and there is no noise or strange movement when spinning the blades by hand.
