Hammermechanicman
- Jan 10, 2020
- Threads
- 56
- 3,532
If you use a fuel can with new fuel line and a filter and the electric pump with a T fitting after the pump and the fuel pressure guage at the T. Turn on the electric pump, bleed the injector pump and the injectors. See what the fuel pressure is. Start the engine and run it till it dies and keep track of the fuel pressure. If it never dies and runs fine. Probably clogged fuel pickup or lines. If it dies with good pressure on the guage issue with injector pump. Probably with the fuel solenoid. If fuel pressure drops off and it dies you need a priest for an exorcism.
