Neo7
- Apr 18, 2012
- 158
Ok thanks for clarify that. I'll consider doing the same but I'm a bit reluctant because I've never had that engine idling and running as sweet as it does at the moment ... so might "let sleeping dog lay" lol!Not the main jets in the emulsion tube I took all that off to expose the other jets, it ran rich so I put another new Chinese carb on it except I used the stock choke plate because it has a single lever for choke and throttle, It has a different arm on it and flips it the other way, it starts right up and doesn't run rich now I think the choke plate function was messing me up from the get go.
Thanks for all the information ... You've done really well in such a short space of time ;-)
