l008com
- May 25, 2015
- 337
This year when I fired up my snow blower for the first time, the engine was a little funny. It surges kind like the choke is on, but it does this with no choke on. And under no load, if I put it on half choke, it kind of smoothes out.
We just got a big storm so I was clearing my driveway and what was interesting was that the machine would surge like crazy UNLESS it was chowing down on snow. Under snow load, the engine would smooth right out. Then as soon as it was done, it would start surging again.
It also conks out at about 25% throttle, so you can't leave it idling at "turtle" while you go clear off a car.
This behavior is all new. This is a 5 year old blower and it has always run great before this. I always change the oil ever spring. It did have half a tank of stabilized old gas in it from last winter. But once I burned through that, I put in fresh gas and the engines behavior was exactly the same.
The last thing I did was put a good amount of sea foam in the current gas, though I haven't used it yet so none of that has actually gone through. And I was planning on replacing the spark plug today for good measure, and hoping between those two things, one would be the fix.
Here is a clip of it surging under no load:
https://www.youtube.com/watch?v=E4s6obZD8zQ
