I have a Honda GX110 engine that has a water pump on it.   It is an older engine that is in like brand new condition.   It has sat around for about 10-12 years with out being used.  It had gas in it and of course it had gone bad.   I replaced the carb, cleaned the tank, replaced the filter and gas line and the spark plug.   I cant get it to run for one a couple of seconds when i spray carb cleaner in the carb.   When i do this and try and start it it revs up for a second or two (seems like just enough time to burn the carb cleaner) and then quits.   There is no low oil sensors.    I assume that because it will run when i spray carb cleaner in the carb that the carb is working.  I took the  new carb apart just to make sure there was nothing strange going on inside and it all looked good.
I cant figure out what is happening and why it wont run. Does anybody have any ideas?
Thanks
Thanks
