firedawgsatx
OP, what's the digit after the E in the model number.
Should be E1,E2 etc.
EDIT. ( I looked up both variants e1&e2, sump part number is the same)
It is E1.
.076" is WAY too much press fit.
You've got the wrong seal.
If the hole was a different size it would be a different part numberI searched on the internet and found several photos of sumps with the same part number and they all appear to be identical to the one I have. Of course, there could be a difference in the diameter of the opening.
Yes You have the wrong oil seal
Oil seals should be a class IV transitional fit or a class V interfearence fit
A type IV should be able to be fitted with finger pressure or a light mallet
A type V should be able to be fitted with a "Light Press" or heavy mallet.
Oil seals should be around these tightnesses
https://www.engineersedge.com/class_iv.htm
GO down the table and for the seal diameter of around 2.5" your crush should be between 0.0002" to 0.0024" .
This is a tad looser than the measured 0.067"
With oil seals , the crush is generally the thickness of the rubber that coats the steel case so removing & replacing it will not damage the hole ( in theory ).
I would email or call Briggs with your model and code date numbers.
They should tell you
You have already measured the hole diameter and shaft diameter so just measure the thickness and order a new oil seal from a bearing supply shop.
All seals used on mowers are a common size.
They have to be in order to reduce costs.
Just go to a real bearing store and not some fly by night online shop flogging junk from 3rd world countries.
