firedawgsatx
I am in the process of replacing the crankshaft oil seal (p/n 399781S) on a B & S 12S512-0118-E engine. The engine is leaking oil on the floor from that seal. I had purchased a used Troy Bilt pressure washer last summer. The engine runs really good but the oil leak is annoying. I decided to replace the seal. When I removed the water pump from the bottom of the engine I saw that someone had apparently installed the oil seal upside down and apparently the cause of the leak. I could not remove the oil seal the traditional way because the seal was pushed all the way down and into the recess where the camshaft passes through the oil sump. So I removed the sump and with a lot of difficulty I was able to remove the upside down seal. I cleaned up the oil sump and when I attempted to install the new seal it appears the seal is too large to fit into the opening. I am attempting to install the new seal with the sump removed from the engine. I checked the parts diagram and it shows I ordered the correct seal. The parts diagram shows the sump is part number 498983. I tried to gently tap the seal into the opening on the sump but the seal's diameter is a little too large. I am hoping to get some advice or tips on installing this seal. Is it better to re-install the sump onto the engine and then install the seal using a proper diameter piece of pipe or socket? I used lube on the outside of the seal and the opening in the sump. Thanks!
