JDgreen
JD, Just because I'm curious ...... What blades etc. have you tried ??????
I had a 318 and had very little problem with clumping and a 2nd pass would nearly always solve the problem.
BK, I had a 318 myself, and it would chop up grass a LOT better than my 4210 does, my cop neighbor has a small Craftsman lawn tractor and his deck chops up grass a lot better than my JD does. I am currently using Gator mulching blades, only about 40 hours on them. My deck simply will not recut grass worth a (BLEEP) instead it just picks up the cut stuff and blows it back out.
Took this picture last night, I was cutting dry 5 1/2 inch high grass with the mower deck set at maximum cut height of 3 3/4 inches, and the discharge chute was propped open, yet look at the grass clippings piled up in front of the deck !!! GRRRRRR!!!!!!
