- Nov 29, 2014
- Threads
- 64
- 24,729
Scott,
You can put whatever oil you like in your Tractor ( sorry Harley )
It is your bike so you are entitled to do with it what your like.
And no I do not own, never have owned nor have any desire to own one.
I have a fleet of motorcycles from 1912 through to 1972 that all work perfectly and many of which have been fitted with modified clutches to run better in the oily primary drive case.
What I do object to and requires correction is that mower specific oil is not required in mowers.
To an extent this is true if you are happy to waste money by using oil which exceeds the makers recommendation in all properties.
Doing so is simply spending more than you need to & if you are happy to do so then again it is your mower & you are entitled to put whatever oil in your mower that you wish.
However a person reading it see a message that translates into "Car oils are fine for mowers" and in general they are not .
Some will be & some won't.
People with no knowledge of proper oil evaluation , let alone oil chemistry are easily confused and of course we all think in conspiracy mode ( they are all the same , just different colours & prices )
I was taught about oils both at college & university , gaining just enough knowledge to know to leave it to the experts and to be able to tell BS endorsement , testimonials & advertising claims from properly done scientific testing & evaluations.
MOWER OILS ARE SPECIFICALLY BLENDED FOR USE IN AIR COOLED MOWER ENGINES AND HAVE EVERYTHING THAT YOUR ENGINE NEEDS FUNCTION PROPERLY AND NOTHING IT DOES NOT NEED , SO IS THE BEST OIL TO PUT IN THERE .
Other oils will also work.
A mix of white spirit & kerrosene will work in your gas tank, but petrol works better .
As for synthetic or semi-synthetic oils most are way more expensive than generic mower oils and way above the specifications required.
As for the popular tag, dino oil a stupid description as all but the most expensive supposedly synthetic oils are plain oils mineral oil, made from plant remains, split into all the easy to separate parts then recombined so stuff not needed can be sold to some one else.
True synthetic oils are synthised from gas, coal seam gas or oil gas usually then chemically converted into oil, ie made from some thing that was not oil in the first place.
They came into being as a method of using waste by-products from mining or refining.
Most of the stuff we use in bulk is made the same way.
Commercial flour is all "synthetic" because the wheat/ corn/ maize is ground down really find separated into it parts on a molecular level the combined in the exact ratios needed for high speed commercial factory baking.
So I can run my mower on $ 10/ qt mower oil or $ 75/ qt fully synthetic oil
It will run just the same most of the time, however if I lay it up over extended winter periods, the synthetic might not offer the same corrosion protection & water isolation that the cheaper mower oil does.
Weather this is a problem for me will depend upon the micro climate where my mower is kept & how long it sits there & weather the oil was fresh or stale.
If mower oil is used it will protect the engine regardless of the local enviroment, the same MAY not be true for auto oils.
So while I can agree with you that you don't need to use mower oil in your mower, the fact remain that mower oil is the best oil for your mower.
