Boudreaux In Eunice La.
Ok a flywheel key should fit in there nice and snug. Always use Briggs keys never a homemade steel key....
Dat's a NO NO on using gasket sealer on any carb.. Dat stuff comes loose and makes your engine run bad.....That might your problem all along....
It doesn't matter if you just smeared a thin layer or a thick layer on there... If a gasket alone won't seal the 2 mating surfaces then something is warped and not right.....
Plus Tard Mon Ami ~!~!
