I have followed the procedure for adjusting the Valves (several -actually many times) but the engine continues to not turn over due to compression build up. Need to know what may be the next most logical thing to check. Basic procedure was to remove valve cover and spark plug, turn engine clockwise to the point that indicated the piston is at the top (using a dowel inserted in the spark plug hole) -- then rotate clockwise for a 1/4 inch lowering of the piston top -- then adjust valves using feeler gage (5-7 thousands for Exhaust valve) and (3-5 thousands for the Intake valve.
Any suggestions would be helpful and appreciated.
