OK... Let's See Your Mower!
I bought this brush trimmer a few weeks ago for $50. It needed the carburetor cleaned and I made an improvised primer bulb. Now it works pretty well. I have a lot of heavy brush to cut, after years of neglect.
youtube .com/watch?v=CxRGu8XJel8
(can't post links, so maybe the text above will be allowed)
I've tried everything I know to rotate this pic but can't fix it. Anyway, this exhaust setup sounds fantabulous! Along with a couple of other mods to the intake, the engine now runs cleaner and stronger. I have two videos with very good audio of the development of this exhaust. One with a long straight pipe and the other with the pipe shortened and the muffler added. Tony Anders on Youtube.
Because you took it with a mobile phone and most likely an Apple one.
What you have to do is save the photo to your computer, then rotate it with your favourite picture editing application then "save as" or "save a copy" using a different file name .
I will then appear correct on the forum.
I will post my photo once I finally bought the one that will suit my lawn and budget. For the meantime, I had a great time browsing the photos of mowers! It could help me make decision on which mower to choose.
You are correct that I took the pic with an Apple cell 6S. I DID save it to my pc, rotated it, saved, and it still comes out 90 degrees rotated. I did not save it as a different file name. Thanks for the info. Maybe one day I will get out of the 3rd grade in my pc education.
