Cannot remove screws from hull of mower to access pull string.
oncaym
  • / Cannot remove screws from hull of mower to access pull string.
The screws on the hull just keep turning both ways and will not come out. I do not know if they are stripped or what to do. If anyone can help please let me know??
What engine are you having problems with.. Honda, Kohler, Kawasaki, Briggs, Loncin, Lausen, Tecumseh, LCT, Subaru, Yamaha, Rato, without a model number from the mower and engine we have no idea what you have to work on.
EngineMan
Try and get something under the head of the screws to lift it up and then unscrew it.
nbpt100
What do you mean by HUll? Can you upload a few pictures?
The Chairman
This is the best answer so far. Next step, is to grind the heads off of the fasteners. You'll probably have to drill and tap to the next size up to put it back together, though.
Romore
They may be rivets, you might have to remove the shroud to service the rewind. May also be stove bolts and nuts.
