Boudreaux In Eunice La.
- Jul 22, 2017
- 2,154
Bring your unit to the dealer you got it from.... Or call him first to see if there is any charge for the job since you used NON etho gas ..........
Yes drain the gas out of the tank and try new gas, but don't use any sta build or other stuff...
Here is a tip take the spark plugs out and spin that puppy over with the choke on so it will drain the carb on it's own... Then take the choke off and spin some more... This way you will have fresh gas in the bowl. Not the old stuff you had in there..
With the plugs out it's not a drain on the battery............ Oh and check for a mouse nest under the air shroud so you won't over heat your engine ~!~!
Let us know Mon Ami ~!~!
