Replacement for B&S
DeereKubota
Hello, I have a B&S 135202 001501 5hp from a wood chipper and would like to re-power it with another B&S. Can anyone suggest a replacement, used or new?
Thanks.
hrdman2luv
Thanks.
I have a wood chipper with a 5hp, with a bad cylinder. Too bad to hone. Probably too bad to even bore. It's got a 1" straight shaft. It's been tough finding a replacement for it. Good luck with yours.
Usually a 5 Hp will have a 7/8" shaft.
To get a 1" you will have to go up to 10Hp or better.
These engines will have longer strokes and thus be taller so you will have to move the pump higher.
blackchevy3de
I have a good b&s 5hp motor off a craftsman chipper,ive been holding onto, but don't need
Boobala
WELL why don't you PM ( Deerekuboto) and MAKE SURE, he knows that, maybe you fellas can work out a deal !! .. :thumbsup:
